i3rex or Volt?
Discussion in 'BMW' started by altfuelcarguy, Jun 8, 2018.
  1. altfuelcarguy
    altfuelcarguy New Member
    Lease on our Chevy Spark EV is ending. Decided to get a PHEV next. Volt seems obvious choice given our normal 40 miles /day driving and level 2 charging at home. Should we consider the i3rex instead? Cost is a major consideration.
    Sent from my SM-N910V using Inside EVs mobile app
  2. JyChevyVolt
    JyChevyVolt Active Member
    I would lease the Volt because it's cheaper and you already have the Clarity.
    altfuelcarguy likes this.
  3. altfuelcarguy
  4. bwilson4web
    bwilson4web Active Member
    • distance is a log scale
    Viking79 likes this.
  5. PowerWall
    PowerWall New Member
    The Volt. With my volt 13,500 out of 15,000 miles in the first year and a third were electric. All of my 38 mile daily commute is covered by the battery even on the coldest winter days. Each year I jump in my Volt and drive 400+ miles each way for a vacation with no worries. You cant do that in a I3 and you will use much more gas in the Prime unless you can charge at work. If you can charge at work then you can frive you Volt with electric for free.
  6. bwilson4web
    It comes down to a question of requirements. My office was 10 miles away with free chargers between at restaurants and grocery stores. Or I would eat lunch where there are free chargers. These work requirements were easily handled by either the Prime or BMW i3-REx. Today I'm retired so I drive as far and when I want with either car and choose to shop and eat where there are free chargers.
    Cross country on gas, the BMW i3-REx is like a motorcycle, 70 mph in 70 mile legs at 40 MPG. We used it to visit relatives 700 miles away and see the eclipse, a 130 miles away. In contrast, the Prime goes +600 miles which allows driving through expensive gas areas. The 1,200 mile delivery trip had one fuel stop midway following trucks getting 56 MPG. Yet with the Prime I still take pee and wake-up breaks roughly every 150 miles, about 2-3 BMW fuel stops.
    Both cars have dynamic cruise control which is standard on the Prime. Dynamic cruise control means using trucks, SUVs, or other vehicles as pacing cars and significantly reduces the fatigue of cross country driving. Curiously, dynamic cruise control was all but standard on the BMW i3-REx because so many of them were initially leased. In contrast, I found dynamic cruise control was an extra cost option limited to the top trims of the Volt and Ioniq when I looked in 2017.
    Rather than "cant", "different" would be more accurate. All three cars, BMW i3-REx, Volt, and Prime, can support commuting to and from work. All three cars can go great distances on gas. All three cars can come with dynamic cruise control. Pick the one that best matches your requirements and enjoy.
  7. bwilson4web
    Work did not have an EV charger but within half a mile, there were two, L2 chargers, #1 and #2. So at lunch, I would get an hour charge:
    • 3.6 kWh - Prius Prime
    • 7.2 kWh - BMW i3-REx
    Work was the center of the blue, dashed circle:
    Both cars got ~4 mi/kWh:
    • -2.5 kWh - 10 miles to work
    • -0.25 kWh - 1 mile to lunch
    • -2.75 kWh - to work and lunch
    • +3.6 kWh - charge during lunch
    So the morning commute was 'free' other than having to eat lunch each day. Now charger #3 is the BMW dealer that is 2 miles away, -0.5 kWh. On the way home, #4 is about the same distance as from work to home but the L2 charger tops it off. Downtown, #5 is a fast DC charger, the BMW i3-REx, but no supermarkets, just restaurants and bars. Airport Road, #6 is close to more fast food and restaurants but no supermarkets.
    The point is lacking a charger at work, check for a nearby charger close to a place to eat. If the distance is <10% of the commute distance, it is functionally the same as having a charger at work.
  8. JyChevyVolt
    For a 2 car household, I would get a pure BEV and a PHEV. No real advantage to owning two PHEV.
    For example:
    Wife commute is less than 5 miles.
    Good candidates are Pacifica, Outlander PHEV, Clarity PHEV, Ioniq PHEV, and Niro PHEV. Noticed, I left off the Volt, i3 and Prime because her car will serve as a road trip car, making these cars too small in passenger and trunk space.
    Me, 80 mile commute
    Any pure BEV with DCFC is all I need. It's strictly a commuter car.
  9. bwilson4web
    It means if either car is down, we still have both local and cross country capabilities. But this is a requirement in our family and others may have different world view.
  10. JyChevyVolt
    Zombie preppers come to mind.:p
  11. bwilson4web
    One car down for two weeks with a broken motor mount bolt.
  12. marshall
    marshall New Member
    I would scratch off the Hyundai and Kia products. The lack of a PTC electric heater makes this car just a plain hybrid for most of the USA for six to eight months out of the year. Does any other manufacture not use a PTC or heat pump in their PHEV versions?
    Plus, if you try to use the car in EV mode too much the air conditioner will start to stink since it doesn't dry out well enough.
  13. JyChevyVolt
    Let me take a wild guess. It was the bimmer?
  14. Viking79
    Viking79 Active Member
    I have two PHEVs, but must admit 1 BEV would have also worked. Always rental car companies if something breaks.
    The reason I wanted the i3 Rex and Clarity PHEV is convenience, either car can make long trips.
    I would price both, see what you can get a deal on, etc. I bought my i3 Rex used but only 5k miles.
  15. bwilson4web
  16. Jully
    Jully New Member
    I will suggest you BMW i3-REx because it gives you more mileage of car and it has many advantages over that. It give 7.2 kWh - BMW i3-REx mileage. for more information, you visit Skype Customer Service which helps me a lot.
