HondaLink App Update
Discussion in 'Clarity' started by vicw, Mar 25, 2019.
  1. vicw
    vicw Active Member Subscriber
    I just updated the Android version of the HondaLink app. I'm not at all bothered by the loss of the infamous EV Charge percentage, but I am concerned with the persistent Notification that HondaLink is Connecting, with the only option being to Dismiss it. The data shows after I Select Dismiss, but after I exit the app, the Notification continues. Even if I select the Notification to be minimized, it still persists.
    That looks like a possible battery drain issue.
    I just noticed that in Settings/Apps & Notifications/App Info for the HondaLink App showed a double Notification selection - both shown active. I turned off the second one, and I'm not seeing the persistent notification. Not sure what other effect that may have.
    ClarityDoc likes this.
  2. leehinde
    leehinde Active Member
    Just updated on iOS.Only downside is that I had to log in again and it didn't like my password (which worked fine on the web site (!)). So, I reset it to what it was and all was well. HondaLink on the web is here: https://hondalink.honda.com/#/
  3. Rav
    Rav New Member
    As much as I'm annoyed by the lack of a battery charge % level, I would've been ok with it if the new app update would have corrected issues I previously had. Now on top of the old issues, I have new issues. The clarity is seriously an afterthought to Honda. Something as simple as when I open the app, it shows me a picture of a Honda van instead of the vehicle I drive, absolutely lame. Clearly, Honda uses bottom of the barrel app developers.
    Peter CC likes this.
  4. MPower
    MPower Active Member
    Yeah, I hate apps that make you sign in every time they update. For folks with automatic update, they can find themselves frozen out just when they want to call Honda Assistance.
    Never mind which vehicle appears on the splash screen, why do we need a splash screen at all. We know it's HondaLink, we just clicked on the icon. Duh.
    neal adkins likes this.
  5. KentuckyKen
    I like seeing the % SOC, so I’ll not be updating. For those who have, how many bars do you get in the graphic display in lieu of the %?
    Peter CC, Texas22Step and Ceetee like this.
  6. vicw
    Just a single, analog bar on the EV with a remaining miles readout
  7. KentuckyKen
    Thanks. I was wondering how many segments it has. As in how fine a detail it gives you.
  8. vicw
    No segments, but on the other hand, the HV display has 5 segments
  9. Alex0913
    Alex0913 Member
    I can now see where the car is at all times, except when it’s moving. I couldn’t see it before the update. It always gave me the location of my phone.
  10. vicw
    I never had that problem with "Find my Car". I'm using Android. It always gave me the actual location of the car, but the "Location" feature, which seems to be gone now, didn't work reliably.
  11. MNSteve
    MNSteve Well-Known Member Subscriber
    I am not seeing an available update. Did you do something special to get it?
  12. vicw
    Not on Android - it showed up on Google Play Store with no prompting on my part.
  13. RickSE
    RickSE Active Member
    F2A405B8-1CAC-4839-8F99-1D8CDD59D99E.png Here’s a bug they didn’t fix. Battery level shows blank if I don’t plug the car in. Doesn’t happen all the time - but happens pretty often.
  14. vicw
    Haven't seen that one yet, in over a year. Maybe it varies from one vehicle or cellular signal strength to another.
    Kailani likes this.
  15. MNSteve
    I updated the app. After logging in, it refuses to do anything or tell me anything about the Clarity. It has a page for my CRV (with no information), and when I go to the Account Setting page it has a "Manage Subscriptions" entry for the Clarity, which says it is active, but all of the Clarity-related functions are no longer accessible. This is the IOS version.
  16. su_A_ve
    su_A_ve Active Member
    I do see it on occasions but only if the car is in a weak cell signal area.
  17. Edward Dries
    Edward Dries New Member
    Top center of app it shows the current vehicle selected. Click on it and you will see other Honda link vehicles. Select which one you want to control.
    Not very intuitive, I did not know how to change vehicles at first either.
  18. MNSteve
    Wow. You're right. I knew how to change vehicles in the previous version.
  19. Ceetee
    Ceetee Member
    01SB, Yvar, JJim and 2 others like this.
  20. ClarityPHEVer
    ClarityPHEVer Member
    Thanks for the heads up not to update. Several months ago when they took away the time estimate for charging, I didn’t update until they made me do so by locking the app. I suspect that will be the case again after a while.
