EV Range
Discussion in 'Clarity' started by TigerTown, Mar 20, 2018.
Tags:
  1. LegoZ
    LegoZ Active Member
    Nice! You have me beat!
  2. Wall-e
    Wall-e New Member
    I dont know what more amazing, Only using a half tank of gas in 5 months or that EV range. What is the actual longest distance you have gone on EV?
  3. Rich Shaffer
    Rich Shaffer New Member
    about 58 miles roundtrip. No heater & few highway miles. Use Regen paddles religiously to slow down. Now that it is warmer here, hope to get more.
  4. dstrauss
    dstrauss Well-Known Member
    HOW in teh world did you get over 70?
  5. Rich Shaffer
    Recent warm weather, 80% city/20% highway miles, Judicious Paddle regenerative braking.
  6. dstrauss
    That last point is quickly becoming my biggest irritant with the Clarity (even more so than XMRadio problems) - they need to issue a software update so the regen paddles work the same in EV as Sport Mode. I am sick and tired of pumping the paddles at every stop (at first I thought this was a waste of time, but as temps have soared into the 90's here it often creates a 0.3 mile jump in battery capacity). What really worse is i find myself hitting the left paddle on my wife's Odyssey which actually DOWNSHIFTS the transmission in the standard 6cyl engine...nuts...
    Hi.Ho.Silver and Domenick like this.
  7. LAF
    LAF Active Member
    Just drive in Sport mode! It is much more enjoyable and if you don't floor it you get the same milage on the battery
  8. Wall-e
    Wall-e New Member
    Does anyone have data on if the regen paddles produces any more regeneration vs normal braking. I'm not convinced the paddles regenerate any more than just normal braking. I define normal braking as coming to a gradual stop without experiencing hard braking.
  9. Kendalf
    Kendalf Active Member
    @Wall-e It's difficult to gauge, as the Honda engineers did a really good job in modulating the regen and friction braking such that I can't tell how much braking is done by one vs the other. You can look at the power gauge and try to see if using the brake pedal only produces a similar green regen strength as using the paddles only (for the same braking force).
    For me, using the paddles is more an assurance that only regen braking is taking place, and then I use the brake pedal only towards the end to come to a complete stop.
    Michael L. likes this.
  10. Jaketesla
    Jaketesla Member
    I'm also not convinced that the paddles are any better than gentle braking. Whenever I tap the paddles to max, the power gauge goes into "charge" but then if I gently apply the brakes the gauge goes even farther into the charge zone.
    I do agree with Kendalf in that I use the paddles as an assurance that the friction brakes aren't being used.
  11. jdonalds
    I believe there is only one regen system, accessed from either the paddles or the brake pedal. I also believe the paddles are calibrated so they will not engage the physical brakes. So if you are light on the brake pedal you will slow to a stop without engaging the brakes. In general it is more efficient to coast to a stop so the regen can work as long as possible. One thing for sure is if the car is stopped there is no regen. To get the most regen approach stops slowly. As soon as you take your foot off the accelerator and the car begins to slow there is regen going on.
  12. KentuckyKen
    Well, I was going to post a pix of 65.9, but no need to now. The king is dead, long live the kings! (Rich and AGarg).
    At least now I can run the A/C all I want since I’m no longer trying to beat anybody.
    How about another contest? Total miles vs gal of gas used.
    1,800/2 gal for me so far.
  13. insightman
    insightman Well-Known Member
    In the olden days, people had to install a home-brewed, warranty-invalidating mIMA box in their 1st gen Insights to provide the ability to select the level of regen braking. Today, Honda would probably tell you to be happy you only have to pull the left paddle 3 times to get to the 4th level of regen.
    I, too, would prefer the Deceleration Paddle Selection stay in effect in ECON and NORMAL Modes, as it does in SPORT Mode. I'd gladly accept having to re-paddle when I start the car. I'm happy ECON Mode stays in effect when you re-start (unlike SPORT Mode).
  14. LegoZ
    LegoZ Active Member
    image.jpg Testing in progress.
  15. LegoZ
    LegoZ Active Member
    image.jpg By the way heat on high WILL turn on the ICE even at 70F.
  16. Viking79
    Viking79 Well-Known Member
    Good to know, I haven't seen a reason to turn the heat on high though, auto works well, usually set to around 66 to 70, worked fine at 10 F. Is there a reason to set the heat to hi? Makes me wonder if engine starting in the cold might be related to heater power required, might experiment next season.
  17. LegoZ
    LegoZ Active Member
    Good way to force the ICE to stay running without constantly forcing it past the the HV Electric power delivery bar. Also FYI while this is occurring at least at idle it does charge the pack. I went from 33 to 35.2 EV range.
  18. LegoZ
    LegoZ Active Member
    I have results for running out of fuel. In hv mode you lose power but no messages for about a minute then you get a message on screen and request to pull over when safe. I stopped and restarted the car in Econ/ev and drove to a gas station.
  19. LegoZ
    LegoZ Active Member
    Dedicated thread coming with more details
  20. bobcubsfan
    bobcubsfan Active Member
    Just curious. Why would you intentionally run out of fuel?
