Clarity PHEV stops charging before battery is full
Discussion in 'Clarity' started by ilun, Feb 20, 2018.
Has your Clarity Plugin ever stopped before being fully charged?
  1. No, it always charges completely (unless I stop it)
    43 vote(s)
    50.6%
  2. Yes, it sometimes stops on its own before a full charge at various stations
    30 vote(s)
    35.3%
  3. Yes, it sometimes stops on its own before a full charge at ChargePoint stations Only
    12 vote(s)
    14.1%
  1. Rajiv Vaidyanathan
    This is great. I hope it works for my problem.
    I'll update you all. Scheduled to have it installed on Monday.
  3. weave
    weave Active Member
    Has anyone every confirmed that later updates also fix earlier update issues?
    I'm just curious if apply 097 will fix the range issue, for example, for those who have that problem and never applied that update.
    Basically I'd just like to argue with the dealer about the latest issue (the charging fault, which I also experienced) and not have to go through the same convincing on the other ones too.
  4. Alantn
    Alantn Member
    When I got the first 2 SB's applied, they had to be applied individually. It is not the latest would include all earlier updates.
  5. MGV
    MGV New Member
    I posted my results in another thread... Basically, 2 days after 18-097 was applied, the charging interruptions from ChargePoint L2 stations have disappeared.
  6. Rajiv Vaidyanathan
    I had the 18-097 update applied today and went and parked at the problem station at work (I have never had luck charging at this station and have had a great deal of frustration here that I have documented in the past).
    It charged with no problems (I was only down a few kw) and no need to restart. If you're having trouble with some charging stations, please go to your dealership and ask them to apply this update. It is a HUGE relief to have this fixed.
    LegoZ, chris5168, KentuckyKen and 2 others like this.
  8. Rajiv Vaidyanathan
    Here's my typical charge chart BEFORE the update:
    Demian Johnston likes this.
  9. neal adkins
    neal adkins Active Member
    This happened to me a couple of times on a level 2 charger. I suspected It could be from the battery being a little hot from climbing a long grade, and then immediately plugging in to a level 2 charger and getting the battery even hotter.
  10. Steven B
    Steven B Active Member
    Really good news to see. So prior to the update, this EVSE was TRYING to give you around 5.6kW and after the update it was still trying to give you 5.6kW and your car was now accepting it. Longest continuous duration was around 30 min before and the latest session was 50 minutes (only because battery reached full cap). Based on the Honda bulletin, I would have expected the charge rate to decrease for problem chargers such as this.
  11. Rajiv Vaidyanathan
    CONFIRMED: CHARGING PROBLEM NOW SOLVED
    I have now charged three times at my work charger without any hiccup at all. The charging starts at the start and continues smoothly with no stops. Prior to having the software update installed, I had *NEVER* charged continuously until fully charged at this location. I constantly had to start charging using the app. I can confidently mark this issue now as FIXED.
    Thanks, Honda - this was one of my biggest frustrations.
    chris5168 likes this.
  13. dnb
    dnb Active Member
    Great to hear its fixed! Thanks a bunch to the people on this forum I wouldn't have known about this problem... sounds like I'll need to schedule a fix with the dealer in case I need to use a lvl 2 station on a road trip :)
  14. hanman
    hanman Member
    Can you please provide the software update number that fixed your problem SB-???
    Thanks in advance
  15. dnb
    dnb Active Member
  16. hanman
    hanman Member
    Thanks dnb
  17. Stan-O
    Stan-O Member
    Not sure if this is a best place to ask, my used 2018 Clarity stops charging when the battery level reaches the second to last notch on the battery gauge, around 60km. Is that a battery degradation, an issue with the car/charger or some sort of the battery long term life saving setting? I believe the battery range should be closer to 80km.
    Thanks!
    PS. Given how half-baked the whole head unit/steering wheel remote controls are maybe it's too much to ask, but seriously how hard was it to have the color of the car in the info screen match the actual car color?!
  18. insightman
    You didn't show the battery gauge, you showed the range gauge. The range gauge varies according to the efficiency of your previous drives. Does your battery gauge in the instrument cluster not indicate a full charge after charging is complete?
  19. Stan-O
    Stan-O Member
    Ah, you're right, the battery gauge is full. I live on the steep mountain and maybe the car is trying to adjust for it.
