Clarity is Effing Slow
Discussion in 'Clarity' started by WantEV, Mar 9, 2019.
  1. WantEV
    WantEV Member
  3. 4sallypat
    4sallypat Active Member
    Well then get a Tesla if you want quickness.
    I love my Clarity in Sport mode - very torquey!
  4. Heino
    Heino Active Member
    Correct - the Clarity is no Tesla, but you will often times outrun most cars on the road due to instant acceleration from dead stop.
    DaleL and 4sallypat like this.
  5. DaleL likes this.
  6. ab13
    ab13 Active Member
  8. vin seeram
    vin seeram Member
    How did they keep Clarity from turning on ICE for the EV test?
  9. craze1cars
    craze1cars Well-Known Member
    Just don’t push pedal past the click. Engine won’t start, and acceleration will be a bit slower. You can see watching the dash that he wasn’t quite full out with the EV test...he was working the throttle in an effort to prevent the engine from coming on, but there was more room in the blue zone he wasn’t using. Probably cost him a second or two.
    We also have no idea how many people were on board, weight, etc.
  10. Jp1969
    Jp1969 New Member
    Definitely not a speed demon but good enough in Sport mode... I think 0-45mph is pretty decent.
    4sallypat likes this.
  11. Dan Albrich
    Dan Albrich Well-Known Member
    So I was interested in doing better environmental choice. As part of that I wanted great gas mileage. I was willing to sacrifice. I bought a Clarity. I was assuming due to its great mileage that it would barely accelerate if at all-- and I was good with that.
    So I buy the car. Given my last was Subaru Outback (4cyl) stationwagon-- wow, its like being in a race car. So I think a lot depends on what 'normal' means to you. If you put my 2003 Subaru outback on the line with Clarity at a race track, Clarity would win by every measure possible.
    So it all depends on your expectations. Now is it fast? No not really. Is it faster than my last ride-- yes, no question.
  13. I would describe the Clarity’s acceleration as “perfectly acceptable”.
    That said, I don’t think I’ve “punched it” more than a few times in 4 months of ownership. But whenever I did, I was not disappointed.
  14. 4sallypat
    Gotta love that Clarity torque from the EV engine - has a very good low end take off ability.
    Then the ICE has the upper "RPM" torque that added together in Sport mode and I am quite happy.
    Even beats out my wife's 4cyl BMW 5 series.....
  15. Agzand
    Agzand Active Member
    If you floor it in EV mode, the engine will start. I think he was trying to modulate the accelerator and keep the power meter in the blue range. Obviously this will result in slower take off.
    The way to measure acceleration is to warm the engine up in HV mode and then floor it in sport mode. You should be able to get something in the 8.5 second range.
  16. 10sqmiles
    10sqmiles New Member
    I am more interested in 45-70 passing times, as I frequent curvy two-lane roads and need to know if I can take advantage of the passing zones to get around any slow pokes. And it that regard, I consider the Clarity to be marginal.
    vin seeram and KANU like this.
  17. Immediately
    Immediately New Member
    The Clarity is “fastest” in HV charge mode + sport mode. At least response-wise, it seems to pick up quicker since the engine is already running and able to generate extra power with less of a delay. It definitely seems to noticeably improve the speed, but for most of us, it’s a mode that we would rarely be using.
  18. neal adkins
    neal adkins Active Member
    "Fast enough" is subjective. Compared to what? If you want a race car go buy one. This topic has been talked about and most people are very pleased with the performance. The Atkinson 1.5 ltr is not designed for maximum torque and accelleration but rather favors efficiency. But when combined with the torquey electric traction motor i find it very acceptable both off the line and in passing situations. But if all that matters is being a speed demon then get an old civic and trick it out for speed. However I think the clarity would out perform the car in your avitar.
  19. insightman
    HV CHARGE Mode diverts some power from the ICE-powered starter motor/generator to charge the battery. I would say that the Clarity PHEV is "fastest" in simple HV Mode, when all the power from the ICE-powered starter motor/generator joins with power from the HV battery to drive the traction motor at its maximum of 181-hp.
    SPORT Mode, indeed, maps the accelerator pedal to feel more responsive, but the maximum acceleration is the same in ECON, NORMAL, or SPORT mode when the accelerator pedal is floored.
  20. LAF
    LAF Active Member
    did you have it in sport mode- I have no problems passing peopler
  21. RickSE
    RickSE Active Member
    Lately I’ve been using HV mode on the highway. Between 60 to 75 MPH on a fairly level road the gear icon comes on and the engine is driving the wheels. At the same time I’m noticing that the battery is also being charged. The engine isn’t running at a noticeably higher RPM (no angry bees) and my battery charge is staying relatively stable. I keep up with traffic just fine too.
