Clarify screen wear
Discussion in 'Clarity' started by Fast Eddie B, Jun 28, 2020.
  1. [​IMG]
    Looks like Evfred nailed it. Isopropyl alcohol on a soft cloth and I'm about half way to a "new" screen working up from the bottom...
    Like I said above, live and learn! Just water and microfiber from now on!
    Evfred likes this.
  3. Heino
    Heino Active Member
    Once you clean your screen... get yourself this screen protector. It was recommended a couple of times here on the forum. I added it to my Clarity, and have had no further issues with fingerprints etc. on the screen.
    https://www.photodon.com/p/2757-01.html
    turtleturtle likes this.
  4. Bits Bytes
    Bits Bytes New Member
  5. I use 70% IPA and water at a 50/50 mix to clean a lot of things. During prep for adding ceramic coating to the car. Even the front and back windows. Clay bar, IPA mix, ceramic. Not much sticks to the windshield now. I'm going to do the same on the inside if I can ever get those two clean enough.
  6. To remove this ad click here.
  7. Naughtysauce
    Naughtysauce Member
    Saw one of these while shopping for one and no less on a CPO from Honda which I thought was a joke. Dealer said he would try to replace it if I made the deal that night which I did. The next day, he said he couldn't replace it as it didn't make financial sense on a used car, so they "un-wind'ed" the deal and I returned the car. But I did see this issue in almost every Clarity I test drove.
    From my understanding, there might be an anti reflective layer which can wear off with a combination of touching the same touch points hundreds/thousands of times along w/ improper cleaning IE- using Windex or other abrasive liquids to clean the screen. Same thing happens to my glasses w/ an anti reflective coating on them, it eventually wears and flakes off. The used example I bought had very minor wear, so the moment I bought it, I got a glass screen protector and installed it to protect from further damage.
  8. Since I cleaned mine with alcohol, it shows virtually no wear at all. Leads me to think the actual glass or acrylic or whatever is pretty darn durable and all my apparent “wear” was just uneven wearing away of wax/cleaner buildup.
