Chrome Grill Delete
Discussion in 'Clarity' started by Hobbesgsr, Mar 11, 2018.
  1. 2002
    2002 Well-Known Member
    I guess if the thief was too lazy to go out into a parking lot and take a photo of any random license plate.
    I think it's the same with VIN numbers, people block those out in photos, and yet anyone who wants to do whatever bad things with VIN numbers just has to walk out into the parking lot and get as many as they want by looking at the base of the windshield of any car.
  2. insightman
    insightman Well-Known Member
    Probably won't be many random Claritys in the parking lot, however. I was postulating the ticket-writer might have access to a database of what kind of car each license plate is linked to. OK, my scenario has stretched too far now. I give up.
  3. fotomoto
    fotomoto Active Member
    It is not a long term solution especially on the front or anything subject to a lot of wear (wheels, etc). BTDT
  4. Walt R
    Walt R Active Member
    In the last few days I saw a program where they blurred out the license plate of a taxi they were using - while the taxicab commission identifier for the vehicle was plainly visible on the roof. Seems to me if I wanted to find that taxi, I'd use the taxi registration before using the license plate.
  5. BeMurda
    BeMurda Member
    @Kevin Kim
    Hey all, I might be interested in front chrome delete, I am just wondering how it is done since the chrome goes into the actual headlight assembly. Did the shops need to disassemble the headlight? If that's the case, I will not do it as many times the light is then compromised and will fog up etc.
  6. Eddgie
    Eddgie Active Member
    Most people seem to be having it vinyl wrapped, but if it were me, I would just do Plasti-dip. Easy to do at home and less than $15.
    The trick to Plasti-dim is to dust on the first couple of coats (not full coverage, just a slight mist). Putting on a couple of dust coats makes it very easy to peel off the Plasti-dip later. If you start with thick coats, it won't peel off easily. Dust coat though, get a little corner up, and the whole thing will peel off in one piece.
    KentuckyKen likes this.
