CD reader/changer like sound when Climate Control is ON
Discussion in 'Clarity' started by kunz427, May 8, 2019.
  1. kunz427
    kunz427 Member
    Hi all, when I run the AC to cool the cabin, I hear a sound similar to a CD reader/changer.That's the closest sound I can compare it to. It comes and goes, maybe it's it the vent opening and closing? Any knowledge on this would be appreciated.
  3. petteyg359
    petteyg359 Well-Known Member
    I've noticed that too. The sound occurs every several seconds, AFAIK the whole time the climate control is on, but I generally only hear it when I park somewhere quiet and sit there in the car for a while before turning it off.
  4. kunz427
    kunz427 Member
    Ok, I hear at when vehicle is stopped or moving at very low speed.
  5. Steven B
    Steven B Active Member
    I've surmised that it is the servos (tiny motors) moving the dampers to re-route airflow in the ductwork.
  6. fotomoto
    fotomoto Active Member
    I would also guess servo motors in the HVAC box adjusting flow direction. See if the recirc/fresh buttons change when this sound occurs.
    My second guess is the electric a/c compressor itself. Since it can and does run without the ICE on, it's more distinctive and, to me, kind of sounds like an optical disc drive spinning up. That is until the condenser fans come on and drown out all other sounds.
